Introdução
In this guide, we will replace the battery of a 2006-2011 Honda Civic key FOB. This is a fairly simple project that can be completed rather than potentially spending a minimum of $90 on a replacement.
O que você precisa
Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
To reassemble your key FOB, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
