Ir para o conteúdo principal
2006-2011 Honda Civic Key FOB Battery Replacement
O que você precisa
  1. 2006-2011 Honda Civic Key FOB Battery Replacement, Key FOB Battery: passo 1, imagem 1 %32
    • Using the Phillips #0 screwdriver, remove the single screw from the bottom of the key FOB.
  2. 2006-2011 Honda Civic Key FOB Battery Replacement: passo 2, imagem 1 %32
    • Gently lift the outer shell and remove it from the rest of the device.
    • Be careful not to break the clip located at the hole for the key ring that holds the shell in place.
  3. 2006-2011 Honda Civic Key FOB Battery Replacement: passo 3, imagem 1 %32
    • Remove the inner shell from the outer shell by pushing the buttons to loosen the inner shell.
  4. 2006-2011 Honda Civic Key FOB Battery Replacement: passo 4, imagem 1 %32
    • Unclasp the inner shell using the clips on the top and bottom.
    • Careful as to not break the clips as it keeps moisture, dust, and dirt from entering the delicate electronics.
  5. 2006-2011 Honda Civic Key FOB Battery Replacement: passo 5, imagem 1 %32
    • Remove the battery inside of the inner shell of the key FOB.
    • If the battery is corroded, make sure to wear gloves due to battery acid.
    • Do not puncture the battery when removing the old one/placing a new one.
  6. 2006-2011 Honda Civic Key FOB Battery Replacement: passo 6, imagem 1 %32
    • Replace the old battery with a new one.
Conclusão
To reassemble your key FOB, follow these instructions in reverse order.
4 outras pessoas executaram este guia.
Erika Caushi
Membro desde: 03/22/21
250 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 75
Últimos 7 dias: 410
Últimos 30 dias: 2,047
Duração total: 68,779
