Ir para o conteúdo principal
2005 Mazda 6 Electronic Throttle Body Replacement
O que você precisa
  1. 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: passo 1, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: passo 1, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement, Electronic Throttle Body: passo 1, imagem 3 %32
    • Open the hood and prop it open.
    • Locate the electronic throttle body.
  2. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 2, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 2, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 2, imagem 3 %32
    • Detach the electric connection from the electronic throttle body.
    • Unplug the safety pin.
  3. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 3, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 3, imagem 2 %32
    • Unscrew the clamp that connects the intake hose to the air filter housing.
  4. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 4, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 4, imagem 2 %32
    • Unscrew the clamp that secures the intake hose with the electronic throttle body.
  5. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 5, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 5, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 5, imagem 3 %32
    • Disconnect the intake hose from both sides.
  6. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 6, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 6, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 6, imagem 3 %32
    • Disconnect the upper and lower vacuum hose on the electronic throttle body using a pair of pliers.
  7. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 7, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 7, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 7, imagem 3 %32
    • Remove the four screws connecting the electronic throttle body to the intake manifold.
  8. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 8, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 8, imagem 2 %32
    • Place the new electronic throttle body on the intake manifold.
  9. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 9, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 9, imagem 2 %32
    • Reattach the four screws securing the electronic throttle body with the intake manifold.
  10. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 10, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 10, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 10, imagem 3 %32
    • Connect the upper vacuum.
    • Connect the lower vacuum hose to the electronic throttle body.
  11. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 11, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 11, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 11, imagem 3 %32
    • Connect the intake hose on both sides.
    • Screw in the clamp that secures the intake hose to the electronic throttle body.
    • Screw the clamp that secures the intake hose to the air filter housing.
  12. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 12, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 12, imagem 2 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 12, imagem 3 %32
    • Connect the electric connection to the electronic throttle body.
  13. 2005 Mazda 6 Electronic Throttle Body Replacement: passo 13, imagem 1 %32 2005 Mazda 6 Electronic Throttle Body Replacement: passo 13, imagem 2 %32
    • The electronic throttle body replacement is done.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Yefri Gonzalez
Membro desde: 04/04/22
244 Reputação
Autoria de 1 guia
Equipe
Um comentário
Bonjour j'ai un Mazda 6 de moteur Essence avec moi mais sa consomme trop et Quel est la solution pour d'autre me disent de changer le catalyseur d'autres me disent de changer la bougie
Sidi mohamed Coulibaly - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 73
Duração total: 1,329
