Introdução
With this step by step repair guide, you will be able to replace a fog light for a 2005 Jeep Liberty.
O que você precisa
Open the hood to access the radiator grill tabs.
Pull up on the first tab and repeat for the remaining four tabs.
Test the replacement light socket by turning the lights on. If working, reinstall the light housing and radiator grill cover.
2 comentários
Thank you for your information, if you are looking for a place that sells the best and most trusted car fog lamps. Check this out!
Thank was easy
