Ir para o conteúdo principal
2005 Honda Accord Headlight Replacement
O que você precisa
  1. 2005 Honda Accord Headlight Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • Pop open the hood of the vehicle.
  2. 2005 Honda Accord Headlight Replacement: passo 2, imagem 1 %32 2005 Honda Accord Headlight Replacement: passo 2, imagem 2 %32 2005 Honda Accord Headlight Replacement: passo 2, imagem 3 %32
    • Remove the headlight connector by depressing the clip and pulling it away from the vehicle.
  3. 2005 Honda Accord Headlight Replacement: passo 3, imagem 1 %32 2005 Honda Accord Headlight Replacement: passo 3, imagem 2 %32
    • Turn the headlight counter clockwise to release it from the headlight assembly.
  4. 2005 Honda Accord Headlight Replacement: passo 4, imagem 1 %32 2005 Honda Accord Headlight Replacement: passo 4, imagem 2 %32
    • Pull the headlight bulb out of the socket.
  5. 2005 Honda Accord Headlight Replacement: passo 5, imagem 1 %32 2005 Honda Accord Headlight Replacement: passo 5, imagem 2 %32
    • Inspect your old headlight bulb and compare with new one to ensure it is the same.
  6. 2005 Honda Accord Headlight Replacement: passo 6, imagem 1 %32
    • Align notches and insert the headlight bulb into the socket.
  7. 2005 Honda Accord Headlight Replacement: passo 7, imagem 1 %32
    • Turn it clockwise until the headlight clips in.
  8. 2005 Honda Accord Headlight Replacement: passo 8, imagem 1 %32
    • Reconnect the headlight pigtail.
    • You will hear a click when the connector is fully seated.
  9. 2005 Honda Accord Headlight Replacement: passo 9, imagem 1 %32 2005 Honda Accord Headlight Replacement: passo 9, imagem 2 %32 2005 Honda Accord Headlight Replacement: passo 9, imagem 3 %32
    • Turn on the vehicle to make sure the headlight lights up.
Conclusão
Uma outra pessoa concluiu este guia.
Diego Avila
Membro desde: 10/05/21
180 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 11-69, Grodsky Fall 2021 Membro de CSU Los Angeles, Team 11-69, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G69
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 53
Duração total: 2,125
