Introdução
An engine air filter is needed to filter the air flowing into the engine.
O que você precisa
Identify the open hood latch. It is located to the left of your brake pedal.
Pull latch toward you. You should hear a click from the front of the car.
Identify the Air Filter Housing. Located to the right of your engine, this is the black plastic box directly above the battery.
4 outras pessoas executaram este guia.
