Ir para o conteúdo principal
2004 Lexus 330 RX Battery Replacement
O que você precisa
  1. 2004 Lexus 330 RX Battery Replacement, Battery: passo 1, imagem 1 %32 2004 Lexus 330 RX Battery Replacement, Battery: passo 1, imagem 2 %32 2004 Lexus 330 RX Battery Replacement, Battery: passo 1, imagem 3 %32
    • Pull up the lever underneath the steering wheel to pop up the hood.
    • Unlatch the hood.
    • The battery should be located on the lower right side of engine.
  2. 2004 Lexus 330 RX Battery Replacement: passo 2, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 2, imagem 2 %32 2004 Lexus 330 RX Battery Replacement: passo 2, imagem 3 %32
    • Use a wrench with a 10 mm socket to remove the bolts of the bracket.
    • Repeat the step above for the second bolt.
  3. 2004 Lexus 330 RX Battery Replacement: passo 3, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 3, imagem 2 %32 2004 Lexus 330 RX Battery Replacement: passo 3, imagem 3 %32
    • Remove the metal rod on top of the battery.
    • The second and third pictures were taken without the battery for a better view of the rod.
  4. 2004 Lexus 330 RX Battery Replacement: passo 4, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 4, imagem 2 %32 2004 Lexus 330 RX Battery Replacement: passo 4, imagem 3 %32
    • Remove the bolts on the clamps with a 10 mm socket.
    • Repeat the process on the second terminal of the battery.
  5. 2004 Lexus 330 RX Battery Replacement: passo 5, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 5, imagem 2 %32 2004 Lexus 330 RX Battery Replacement: passo 5, imagem 3 %32
    • Carefully remove the clamps from the terminal.
    • Sometimes clamps are stuck in place due to corrosion or battery leak. Use caution while removing it.
  6. 2004 Lexus 330 RX Battery Replacement: passo 6, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 6, imagem 2 %32
    • Carefully remove the battery from the engine.
    • Do not tilt the battery while removing it.
  7. 2004 Lexus 330 RX Battery Replacement: passo 7, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 7, imagem 2 %32
    • Insert the new battery in the engine.
    • Place the metal rod back in place.
  8. 2004 Lexus 330 RX Battery Replacement: passo 8, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 8, imagem 2 %32
    • Place the bracket back on top of the battery.
    • Use a wrench with a 10 mm socket to secure the bolts of the bracket.
    • Repeat the above step for the second bolt.
  9. 2004 Lexus 330 RX Battery Replacement: passo 9, imagem 1 %32 2004 Lexus 330 RX Battery Replacement: passo 9, imagem 2 %32 2004 Lexus 330 RX Battery Replacement: passo 9, imagem 3 %32
    • Put the terminal back on.
    • Put the bolts on the clamps back on with a 10 mm socket.
    • Repeat the previous step for the second bolt.
Conclusão
You have successfully changed the battery of Lexus 330 RX 200. Good Job!
5 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 29
Últimos 30 dias: 81
Duração total: 3,868
