Ir para o conteúdo principal
2004-2013 BMW 3 Series Inner Taillight Replacement
O que você precisa
  1. 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: passo 1, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement, Inner Taillight Housing: passo 1, imagem 2 %32
    • Unlock your trunk.
    • This can be done with either the remote or the trunk release button located on the driver's side footwell area.
    • Using the trunk handle, lift the trunk to it's highest position.
  2. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, imagem 2 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 2, imagem 3 %32
    • Using the appropriate trim tool, carefully remove all ten rivets from the trunk liner.
  3. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, imagem 2 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 3, imagem 3 %32
    • Pull on the green tab to release the inner trunk release handle.
    • After this, the trunk liner should be loose.
    • Carefully remove the liner and put it off to the side for later reassembly.
  4. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, imagem 2 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 4, imagem 3 %32
    • Using either a 10 mm socket or an open-end 10 mm wrench, turn the nut counterclockwise to loosen it and remove the bracket that secures the inner taillight.
    • An open-end wrench was used in this guide, however, both tools work for removing the retaining nut.
  5. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 5, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 5, imagem 2 %32
    • From underneath the inner taillight, push the housing with enough upward force to separate it from its socket.
    • Be careful when pushing the housing, as the connector is still attached to the inner taillight.
  6. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, imagem 1 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, imagem 2 %32 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 6, imagem 3 %32
    • Tilt the inner taillight enough to gain access to the connector on the underside.
    • Firmly press the locking tab in the center of the connector.
    • Pull downwards on the connector to disconnect the inner taillight housing.
  7. 2004-2013 BMW 3 Series Inner Taillight Replacement: passo 7, imagem 1 %32
    • Prepare your new taillight for reassembly.
    • Responsibly recycle your old inner taillight if it is no longer functional.
Conclusão
To reassemble the inner taillight, follow these instructions in reverse order.
Jason Tech Tips
Membro desde: 09/05/23
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 44
Últimos 30 dias: 77
Duração total: 259
