Ir para o conteúdo principal
2003 Toyota Solara Tail Light Replacement
O que você precisa
  1. 2003 Toyota Solara Tail Light Replacement, Tail Light: passo 1, imagem 1 %32
    • Park the vehicle and turn off the engine.
    • Step on the brake pedal to confirm whether or not the tail light is responsive.
  2. 2003 Toyota Solara Tail Light Replacement: passo 2, imagem 1 %32 2003 Toyota Solara Tail Light Replacement: passo 2, imagem 2 %32 2003 Toyota Solara Tail Light Replacement: passo 2, imagem 3 %32
    • Reach underneath the steering wheel. Then, place your hand to the left to remove the fuse box cover.
  3. 2003 Toyota Solara Tail Light Replacement: passo 3, imagem 1 %32 2003 Toyota Solara Tail Light Replacement: passo 3, imagem 2 %32
    • Reference the fuse box guide on the back of the cover.
    • Locate the fuse number that corresponds to the tail light (2nd column, last row).
    • Replace the tail lamp if the fuse is still functional.
  4. 2003 Toyota Solara Tail Light Replacement: passo 4, imagem 1 %32 2003 Toyota Solara Tail Light Replacement: passo 4, imagem 2 %32
    • Open the vehicle's trunk.
    • Unscrew the plastic fastenings located inside the trunk.
    • Detach the panel covering the tail light.
  5. 2003 Toyota Solara Tail Light Replacement: passo 5, imagem 1 %32 2003 Toyota Solara Tail Light Replacement: passo 5, imagem 2 %32 2003 Toyota Solara Tail Light Replacement: passo 5, imagem 3 %32
    • Untwist the wired socket to expose the lamp bulb.
    • Check the bulb for discoloration (if it is clouded, replace the bulb).
  6. 2003 Toyota Solara Tail Light Replacement: passo 6, imagem 1 %32 2003 Toyota Solara Tail Light Replacement: passo 6, imagem 2 %32
    • Insert the new bulb into the socket.
    • Push until there is an audible "click".
Conclusão
To reassemble the tail lamp, follow these instructions in reverse order.
Melissa Spinali
Membro desde: 04/28/17
107 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team S2-G2, Cole Spring 2017 Membro de UC Davis, Team S2-G2, Cole Spring 2017
UCD-COLE-S17S2G2
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 52
Duração total: 2,756
