Ir para o conteúdo principal
2003 Ford Taurus Headlight Bulb Replacement
O que você precisa
  1. 2003 Ford Taurus Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 2 %32 2003 Ford Taurus Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 3 %32
    • Open the hood of the car by pulling the hood release lever located inside the car. The lever can be found on the driver’s side, down and to the left of the emergency brake release. It should contain a symbol of a car with a raised hood.
    • After pulling the lever, the hood should pop up slightly. To raise it fully, first release the safety latch, located centrally on the front of the hood, by pushing it all the way to the left.
    • Pull the hood all the way up.
  2. 2003 Ford Taurus Headlight Bulb Replacement: passo 2, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 2, imagem 2 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Using an 8mm socket and socket wrench, loosen the 8mm bolt located on the side of the headlight closest to the car’s center.
    • Find the two black clips located laterally from the 8mm bolt and remove them by prying them up with a screwdriver.
  3. 2003 Ford Taurus Headlight Bulb Replacement: passo 3, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 3, imagem 2 %32
    • Pull the headlight assembly out from the car.
    • Detach the assembly from the car by pressing on the thumb tab of the connecting cord, while pulling the assembly outwards, away from the car.
  4. 2003 Ford Taurus Headlight Bulb Replacement: passo 4, imagem 1 %32
    • Flip the headlight assembly around to expose the back, making various caps and cords visible.
    • Open the headlight bulb cap (the largest cap) by turning it counterclockwise, until it becomes loose enough to remove.
  5. 2003 Ford Taurus Headlight Bulb Replacement: passo 5, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 5, imagem 2 %32
    • After loosening the bulb cap, wires connecting to a bulb holder should be visible. The bulb holder will be held in place by a circular retainer ring. Loosen the retainer ring by turning it counterclockwise.
    • Pull the bulb and bulb holder out of the socket.
  6. 2003 Ford Taurus Headlight Bulb Replacement: passo 6, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 6, imagem 2 %32
    • Firmly grip the bulb with one hand and the bulb holder with the other hand. Pull the two components apart to remove the old bulb, keeping the retainer ring on the side of the bulb holder.
    • Insert the new bulb by aligning it with the connections on the holder and press the two pieces firmly together until they “click.”
  7. 2003 Ford Taurus Headlight Bulb Replacement: passo 7, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 7, imagem 2 %32
    • Align the new bulb and holder with the open socket. Twist the retainer ring clockwise to tighten the bulb into place.
    • Cover the bulb/holder with the headlight bulb cap and turn it clockwise until it holds firmly in place.
  8. 2003 Ford Taurus Headlight Bulb Replacement: passo 8, imagem 1 %32 2003 Ford Taurus Headlight Bulb Replacement: passo 8, imagem 2 %32
    • Reattach the headlight assembly to the car by first aligning the thumb tab on the car side of the connecting cord with the tab holder on the assembly side. Push the two sides together until they hold.
    • Line the headlight assembly up with the car and push it back into place.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Um comentário
Excellent photos! I was looking for a picture of the headlight dust cover seal and you have a very clear image of it.
Jssamp - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 16
Últimos 30 dias: 44
Duração total: 1,956
