Ir para o conteúdo principal
2003-2007 Honda Accord Key Fob Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32 2003-2007 Honda Accord Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 3 %32
    • Use a Phillips #0 screwdriver to remove the screw at the base of the key fob.
  2. 2003-2007 Honda Accord Key Fob Battery Replacement: passo 2, imagem 1 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 2, imagem 2 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 2, imagem 3 %32
    • Insert a flathead screwdriver into the crack between the top and bottom portions of the key fob.
    • Pry upwards with the flathead screwdriver to loosen the bottom portion of the fob.
    • Remove the bottom portion of the key fob.
  3. 2003-2007 Honda Accord Key Fob Battery Replacement: passo 3, imagem 1 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 3, imagem 2 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Remove the inner portion of the key fob.
  4. 2003-2007 Honda Accord Key Fob Battery Replacement: passo 4, imagem 1 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 4, imagem 2 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 4, imagem 3 %32
    • Use your fingers to undo the clips at the top and bottom of the fob's inner portion.
    • Separate the two sides of the fob's inner portion.
  5. 2003-2007 Honda Accord Key Fob Battery Replacement: passo 5, imagem 1 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 5, imagem 2 %32 2003-2007 Honda Accord Key Fob Battery Replacement: passo 5, imagem 3 %32
    • Use a flathead screwdriver to pry up the circular battery.
    • Remove the key fob's battery.
    This is nice except for the fact that it shows the battery positioned upside down.
    essin - Responder
Conclusão
3 outras pessoas executaram este guia.
eCuration
Membro desde: 05/19/17
376.693 Reputação
Autoria de 234 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 16.817 guias
Um comentário
Very clear and helpful video. Everything worked the way it was shown. Cost was less than $5 for battery, found at Walgreens. Thank you!
Debra Burrell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 26
Últimos 7 dias: 257
Últimos 30 dias: 1,420
Duração total: 141,491
