Introdução
Brake pad life varies greatly by driving style and car use. There is no specific mile count at which brake pads should be changed. The best indicator of worn brake pads is a screeching sound when braking. It is recommended that you change your brake pads when this occurs.
O que você precisa
Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
Once car is raised, remove the lug nuts on one of the front tires with the 3/4'' socket.
Loosen the lug nuts before jacking up the car!
Use a 19mm socket
Identify the two mounting bolts on the rear of the caliper.
Using a 12 mm wrench or socket, remove the two caliper mounting bolts.
I found it’s easier to remove only the bottom mounting bolt then lift the caliper to remove the brake pads. The caliper remained in up position and because it was attached it posed no risk of falling off the rotor and damaging the brake line.
26 outras pessoas executaram este guia.
Um comentário
Safety tip - before lifting the car up with the jack, break loss the lug nuts as in step 5, break lose means to get them started but they are still snug. Why - This way you don't have to crank with strength when the car is on the stands and possibly knock it off the stands.
Just for understanding: the crossmember runs from the legt fender to right fender, or am I wrong?
VauWeh - Responder
( I mean left fender)
VauWeh - Responder
Correct-o-mungo!!
Kevin R Brown - Responder
