Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
It is suggested that the cabin air filter be replaced every 15,000 miles.
O que você precisa
Open the passenger side door and locate the glove box. Open and empty the glove box.
Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray.
21 outras pessoas executaram este guia.
Um comentário
Good easy to understand directions and removal of cabin air filter . Thank You
