Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
It is suggested that the cabin air filter be replaced every 15,000 miles.
Ferramentas
Nenhuma ferramenta especificada.
  1. Open the passenger side door and locate the glove box. Open and empty the glove box. Open the passenger side door and locate the glove box. Open and empty the glove box.
    • Open the passenger side door and locate the glove box. Open and empty the glove box.
  2. Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
    • Identify the glove box damper assy latch on the right side of the glove box. Using moderate force, press against the latch with your thumb until it pops out of place.
  3. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  4. The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
    • The glove box is held in place by tabs on both sides. Push inward on both sides of the box to allow the glove box to drop clear the tabs and drop downward slowly.
  5. Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges. Push the tabs inward and gently shake the housing free while pulling straight out. Push the tabs inward and gently shake the housing free while pulling straight out.
    • Now that the cabin air filter housing is visible locate the locking tabs on the left and right edges.
    • Push the tabs inward and gently shake the housing free while pulling straight out.
  6. Push the air filter out of the plastic housing from the bottom and discard.
    • Push the air filter out of the plastic housing from the bottom and discard.
  7. Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy. Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
    • Orient the new filter properly, with the air flow arrows (located on the filter) aligning with the indication on the filter tray assy.
    • Press the air filter down into the housing while draping the filter's thick side pleats into the plastic housing.
    • Ensure that the last vanes on the front and back of the filter fit into the retaining tabs in the filter tray.
Conclusão
17 outras pessoas concluíram este guia.
Shaun MacDonald
Membro desde: 03/10/2012
2.186 Reputação
8 Guias de autoria
Equipe
Cal Poly, Team 24-27, Regan Fall 2012 Membro de Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Membros
18 Guias de autoria
Is it that hard to say i don,t know instead of line of bs. Thank you shaun, saved me time an aggrevation. Your true car guy bro.
Robert McLaughlin - Responder
What are you taking about? What part of this guide is BS?
David Spalding -
Good easy to understand directions and removal of cabin air filter . Thank You
raysanchez120 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 46
Últimos 30 dias: 190
Duração total: 25,172
