Ir para o conteúdo principal
2003-2008 Toyota Corolla Headlight Bulb Replacement
O que você precisa
  1. 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 2 %32
    • Locate the handle to open the hood. It will be on the driver side of the car to the left.
    • Pull up on the handle and the hood should pop open a small amount.
  2. 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 2, imagem 1 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 2, imagem 2 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 2, imagem 3 %32
    • Reach under the hood in the front where there is a small notch and pull the latch up. This will allow the hood to open all the way.
    • Locate the prop and insert it into the hole in the hood.
  3. 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 3, imagem 1 %32
    • Locate the bulb. It will be in the front and to the side. Start with the side opposite from the battery.
  4. 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 4, imagem 1 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 4, imagem 2 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 4, imagem 3 %32
    • Twist assembly 45 degrees counter clockwise and pull straight out.
    • Be careful not to touch the glass on the new bulb. The oils from your hand could cause premature bulb failure.
  5. 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 5, imagem 1 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 5, imagem 2 %32
    • Lift up on the latch and pull. The bulb will come free from the wires.
  6. 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 6, imagem 1 %32 2003-2008 Toyota Corolla Headlight Bulb Replacement: passo 6, imagem 2 %32
    • Locate the other bulb, and repeat steps 3-5 to remove it.
Conclusão
10 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 17-4, Green Fall 2015 Membro de Cal Poly, Team 17-4, Green Fall 2015
CPSU-GREEN-F15S17G4
Membros da 3
Autoria de 4 guias
Um comentário
https://youtu.be/GHezj9nmbxE
Change headlight on your corolla in under one minute. So easy.
baxta777 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 13
Últimos 7 dias: 78
Últimos 30 dias: 402
Duração total: 91,901
