Introdução
You might have found yourself in a situation where your car dies. It happens to everyone at some point. When this happens, the first thing to do is to try and jump it off. If this doesn’t work, it’s likely that your battery is dead. In this case, you will need to replace the battery of your car. This guide will show you how to replace the dead battery with a new one in a 2003-2008 Honda Pilot.
O que você precisa
On the inside of the driver’s side door is a latch the pops open the hood of the car. Pull the latch.
Underneath the hood is another latch to open the hood. Pull this latch and lift up on the hood of the car, revealing the engine.
Use the arm to keep the hood of the car propped open.
There are several places to take your old car battery to be recycled. One of the most convenient places to take you battery to be recycle is AutoZone. Simply place your dead car battery in a plastic bag and drop it off for AutoZone to recycle – free of charge
