Ir para o conteúdo principal
2003-2015 Nissan Armada Cabin Air Filter Replacement
O que você precisa
  1. 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 1 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 2 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 3 %32
    • Open the glove box.
    • Use a Phillips #00 to remove the three screws at the top of the glove box.
    • Place your screws aside in a safe spot to use for reassembly.
    • Lift the glove box out.
  2. 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 2, imagem 1 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 2, imagem 2 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 2, imagem 3 %32
    • Use a socket wrench to remove the 8 mm bolt securing the plastic cover to the cabin air filter.
    • Remove the plastic cover and you should see two air filters next to each other.
  3. 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 3, imagem 1 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 3, imagem 2 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 3, imagem 3 %32
    • Carefully remove the filters starting with the left one as its easier to remove.
    • Now remove the one on the right side.
    • If you are struggling, use your fingers to slide it over.
    • Place the dirty air filters to the side and have the new ones ready.
  4. 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 4, imagem 1 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 4, imagem 2 %32 2003-2015 Nissan Armada Cabin Air Filter Replacement: passo 4, imagem 3 %32
    • Place the first filter to the right side with the airflow arrows pointing down.
    • Insert the second air filter, to the left of the first filter.
Conclusão
Kenneth Maldonado
Membro desde: 09/23/23
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 19
Últimos 30 dias: 68
Duração total: 221
