Ir para o conteúdo principal
2002 Toyota Tacoma Headlight Bulb Replacement
O que você precisa
  1. 2002 Toyota Tacoma Headlight Bulb Replacement, Headlight Bulb: passo 1, imagem 1 %32
    • Pull the lever under the steering wheel.
  2. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 2, imagem 1 %32 2002 Toyota Tacoma Headlight Bulb Replacement: passo 2, imagem 2 %32
    • Pull up on the lever under the hood.
    • At the same time, lift the hood of the car.
  3. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 3, imagem 1 %32 2002 Toyota Tacoma Headlight Bulb Replacement: passo 3, imagem 2 %32
    • Remove the metal rod.
    • Insert the metal rod to hold the hood in place.
  4. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 4, imagem 1 %32 2002 Toyota Tacoma Headlight Bulb Replacement: passo 4, imagem 2 %32
    • Pinch the rubber cover and disconnect the headlight bulb.
  5. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 5, imagem 1 %32
    • Push down on the metal lever to release it. After you have released the lever you can remove the bulb.
  6. 2002 Toyota Tacoma Headlight Bulb Replacement: passo 6, imagem 1 %32
    • Remove the headlight bulb cover when you are ready to install it.
    • Do not touch the bulb or let it touch anything to prevent it from getting damaged.
Conclusão
To reassemble your device, follow steps 3-5 in reverse order. At the end of step 3 make sure to push down on the hood to lock it back into place.
Uma outra pessoa concluiu este guia.
Drake Fenwick
Membro desde: 02/17/21
133 Reputação
Autoria de 1 guia
1Comentário do guia
thank you, saved me alot of time.
harley cortez - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 1,722
