Ir para o conteúdo principal
2002 Nissan Altima Hubcap Replacement
O que você precisa
  1. 2002 Nissan Altima Hubcap Replacement, Hubcap: passo 1, imagem 1 %32 2002 Nissan Altima Hubcap Replacement, Hubcap: passo 1, imagem 2 %32 2002 Nissan Altima Hubcap Replacement, Hubcap: passo 1, imagem 3 %32
    • Attach the retention ring to your new hubcap, aligning the divot in the ring with the tire-valve cutout.
    • Be sure to click the ring in each clip around the hubcap.
  2. 2002 Nissan Altima Hubcap Replacement: passo 2, imagem 1 %32
    • Use a wide tipped removal tool to align the wedge inside the hubcap.
    • You may be able to remove the hubcap with your hands if you grab and pull. Be careful, though, to not injure yourself.
  3. 2002 Nissan Altima Hubcap Replacement: passo 3, imagem 1 %32
    • Gently push on the solid parts of the hubcap until they pop out of the tire.
  4. 2002 Nissan Altima Hubcap Replacement: passo 4, imagem 1 %32 2002 Nissan Altima Hubcap Replacement: passo 4, imagem 2 %32
    • Align the replacement hubcap with the tire valve.
    • There should be a cutout in the hubcap to specifically fit around the tire valve.
  5. 2002 Nissan Altima Hubcap Replacement: passo 5, imagem 1 %32 2002 Nissan Altima Hubcap Replacement: passo 5, imagem 2 %32
    • Keeping alignment, hold the center of the hubcap and forcefully push in all the sides of the inner ring until it secures in place.
  6. 2002 Nissan Altima Hubcap Replacement: passo 6, imagem 1 %32
    • Repeat steps 1-5 for other three tires.
Linha de Chegada
Bre Sanders
Membro desde: 04/26/24
133 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-6, Whithaus Spring 2024 Membro de UC Davis, Team 2-6, Whithaus Spring 2024
UCD-WHITHAUS-S24S2G6
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 224
