Ir para o conteúdo principal
2002-2006 Toyota Camry Windshield Wiper Replacement
O que você precisa
  1. 2002-2006 Toyota Camry Windshield Wiper Replacement, Windshield Wiper: passo 1, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement, Windshield Wiper: passo 1, imagem 2 %32
    • Lift windshield wiper arms off the windshield and into the air.
  2. 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 2, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 2, imagem 2 %32
    • Place your thumb and index finger on each side of the small central mechanism.
    • Gently squeeze the small mechanism together with your thumb and index finger and push the mechanism up.
  3. 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 3, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 3, imagem 2 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 3, imagem 3 %32
    • Carefully, but firmly, pull windshield wiper blades down towards the hood of the car to “unhook” the blade from the wiper arm.
    • Place your towel on the windshield to protect it in case the arm drops onto the windshield.
  4. 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 4, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 4, imagem 2 %32
    • On the driver's side, push the 24" wiper blade up towards the sky and into the hooks on the windshield wiper arm. The new blade should firmly click into place.
    • Repeat on the passenger's side using the 19" wiper blade.
  5. 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 5, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 5, imagem 2 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 5, imagem 3 %32
    • Remove towels or other padding from windshield.
  6. 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 6, imagem 1 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 6, imagem 2 %32 2002-2006 Toyota Camry Windshield Wiper Replacement: passo 6, imagem 3 %32
    • Give both windshield wiper arms a gentle, but firm, shake to confirm that the new wiper blades are secure.
    • Carefully put the passenger's side wiper arm back onto the windshield first. Then put the driver's side wiper arm down on the windshield.
Conclusão
Congratulations, you have properly replaced your windshield wipers!
Lucas Labrador
Membro desde: 10/18/23
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 35
Duração total: 365
