Ir para o conteúdo principal
2002-2006 Toyota Camry Key Fob Battery Replacement
O que você precisa
  1. 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2002-2006 Toyota Camry Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32
    • Purchase a new lithium coin battery. You can find it at your local hardware store.
    • The battery has a "+" positive side (textured surface) and a "–" negative side (smooth surface).
  2. 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 2, imagem 1 %32
    • Use your hands or a spudger to separate the key fob into two pieces.
  3. 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 3, imagem 1 %32
    • Identify which part of the FOB holds the battery.
    • You will not need the other part of the fob until the end.
  4. 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 4, imagem 1 %32 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery from the fob by releasing it from the holder using a spudger or by hand.
    • Be careful that you don't break the contacts when removing the battery.
  5. 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 5, imagem 1 %32
    • Insert the new battery by pushing it down.
  6. 2002-2006 Toyota Camry Key Fob Battery Replacement: passo 6, imagem 1 %32
    • Reassemble the fob, using your hands to press the two parts together.
Conclusão
Salman Abu Mazen
Membro desde: 09/27/21
140 Reputação
Autoria de 1 guia
Equipe
UM-Willis-F21S51G7 Membro de UM-Willis-F21S51G7
Community
1 Membro
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 50
Últimos 30 dias: 241
Duração total: 5,610
