Ir para o conteúdo principal
2002-2006 Acura Integra Hatch Strut Replacement
O que você precisa
  1. 2002-2006 Acura Integra Hatch Strut Replacement, Hatch Strut: passo 1, imagem 1 %32
  2. 2002-2006 Acura Integra Hatch Strut Replacement: passo 2, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 2, imagem 2 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 2, imagem 3 %32
    • Go to the rear of the vehicle.
    • Pull up on the trunk handle to lift open the trunk.
  3. 2002-2006 Acura Integra Hatch Strut Replacement: passo 3, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 3, imagem 2 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 3, imagem 3 %32
    • Prop open hatch or have someone help support the hatch weight.
    • Remove the upper ball mount.
    • Turn the upper ball mount counterclockwise with a 12mm wrench.
    • It will pop off when it's completely unscrewed.
  4. 2002-2006 Acura Integra Hatch Strut Replacement: passo 4, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 4, imagem 2 %32
    • Remove the lower ball mount.
    • Turn the lower ball mount counterclockwise with a 12mm wrench.
  5. 2002-2006 Acura Integra Hatch Strut Replacement: passo 5, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 5, imagem 2 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 5, imagem 3 %32
    • Place a washer on the new upper ball mount.
    • Turn it clockwise to hand tighten the new upper ball mount.
    • Turn it clockwise with the crescent wrench to finish tightening.
  6. 2002-2006 Acura Integra Hatch Strut Replacement: passo 6, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 6, imagem 2 %32
    • Place a washer on the new lower ball mount.
    • Turn it clockwise to hand tighten the new lower ball mount.
    • Turn it clockwise with a crescent wrench to finish tightening the new lower ball mount.
  7. 2002-2006 Acura Integra Hatch Strut Replacement: passo 7, imagem 1 %32 2002-2006 Acura Integra Hatch Strut Replacement: passo 7, imagem 2 %32
    • Place a lower hatch strut socket over the new lower ball mount.
    • Push it firmly onto the new lower ball mount. It will pop on easily.
  8. 2002-2006 Acura Integra Hatch Strut Replacement: passo 8, imagem 1 %32
    • Place the upper hatch strut socket over the new upper ball mount.
    • Press it firmly onto the new upper ball mount. It will pop on easily.
Conclusão
Michael Hagar
Membro desde: 10/07/19
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 689
