Introdução
This guide demonstrates how to remove and replace fuses for your Dodge truck.
O que você precisa
Open the hood by pulling the hood lever in the driver-side footwell.
Reach under the center of the grille and press the hood latch.
To replace a fuse, follow these instructions in reverse order. Make sure you buy the correct fuse to replace a blown fuse. Serious damage can occur if you do not use the correct replacement fuses.
12 outras pessoas executaram este guia.
21 comentários
I need to find the flasher
thanx anyway. but not the answer I wanted. didn't tell me anything about which fuse it was .I looked in the fuse box and didn't c the fuse labled headlight there...
