Ir para o conteúdo principal
2001 Volkswagen Passat Key Fob Battery Replacement
O que você precisa
  1. 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 1 %32 2001 Volkswagen Passat Key Fob Battery Replacement, Key Fob Battery: passo 1, imagem 2 %32
    • Press the release button on the key fob so that key is extended.
    • Locate the small indentation in the middle of the key fob.
  2. 2001 Volkswagen Passat Key Fob Battery Replacement: passo 2, imagem 1 %32 2001 Volkswagen Passat Key Fob Battery Replacement: passo 2, imagem 2 %32 2001 Volkswagen Passat Key Fob Battery Replacement: passo 2, imagem 3 %32
    • Place a plastic pry tool in the indentation of the key fob.
    • Apply pressure and rotate the pry tool until key fob begins to separate.
    • Using light force, pull the key fob apart.
    • Remove the cover on lower part of the key fob and locate the battery.
  3. 2001 Volkswagen Passat Key Fob Battery Replacement: passo 3, imagem 1 %32 2001 Volkswagen Passat Key Fob Battery Replacement: passo 3, imagem 2 %32 2001 Volkswagen Passat Key Fob Battery Replacement: passo 3, imagem 3 %32
    • Use a spudger to remove the battery.
    • Place a new battery in the key fob and press down gently to secure it in place.
  4. 2001 Volkswagen Passat Key Fob Battery Replacement: passo 4, imagem 1 %32 2001 Volkswagen Passat Key Fob Battery Replacement: passo 4, imagem 2 %32
    • Pick up the pieces of the key fob and begin to slide the pieces together.
    • This needs to be done slowly to not break the plastic on the fob.
  5. 2001 Volkswagen Passat Key Fob Battery Replacement: passo 5, imagem 1 %32
    • Press the key release button to make sure that the key fob operates correctly.
    • Press the lock, unlock and trunk buttons and check for the red indicator light to make sure the key fob working properly.
    • Depending on your vehicle, you may need to reprogram your key fob to your car. Either consult a dealership or review your owner's manual on how to reprogram your key fob.
Linha de Chegada
5 outras pessoas executaram este guia.
Alisha Kocjan
Membro desde: 04/01/16
236 Reputação
Autoria de 1 guia
Equipe
2 comentários
verry useful!!
eugen - Responder
My neighbor's key broke off the end for her 2001 Passat. She knowing that I am quite handy, asked me if I would try repairing it. I fixed it twice before. Now, instead of simply applying JB Weld again to the minimal surfaces and temporarily fixing it again, I want to disassemble it and repair the key with silver solder. I need a diagram of taking it apart so I can reassemble it so it functions like a new fold-up key fob should. This is such a handy thing, I just need to a diagram. C'mon, VW? Be a sport?
ironchip - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 24
Últimos 30 dias: 79
Duração total: 19,280
