Ir para o conteúdo principal
Introdução
Replacing the rear differential on a 2001 Audi TT
Ferramentas
Peças
Nenhum componente especificado.
  1. 2001 Audi TT Rear Differential Replacement, Getting Started: step 1, image 1 of 1
    • Lets get started! A car lift is recommended for this task but it can be done with just a jack if required.
  2. 2001 Audi TT Rear Differential Replacement, Remove the exaust and exaust shield: step 2, image 1 of 1
    • The exhaust is held in with two bolts at the middle of car underneath . It the hangs from 4 rubber mount wich can be unhooked with a small screw driver and some leverage.
    • Be careful not to tear the rubber mounts.
    • Sorry for missing images they were never taken during the exhaust removal.
  3. 2001 Audi TT Rear Differential Replacement, Axles: step 3, image 1 of 1
    • Dismount both axles from the rear differential.
  4. 2001 Audi TT Rear Differential Replacement, Ground Strap: step 4, image 1 of 1
    • Dismount the ground strap located to the left of the driver side rear axle hub.
  5. 2001 Audi TT Rear Differential Replacement, Drive Line Hub: step 5, image 1 of 1
    • Dismount the drive line from the rear differential.
  6. 2001 Audi TT Rear Differential Replacement, Remove Tank Shield: step 6, image 1 of 1
    • Removing the passenger side gas tank shield will make step 7 easier.
  7. 2001 Audi TT Rear Differential Replacement, Remove Bracket: step 7, image 1 of 2 2001 Audi TT Rear Differential Replacement, Remove Bracket: step 7, image 2 of 2
    • Remover the two main bolts.
  8. 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: step 8, image 1 of 2 2001 Audi TT Rear Differential Replacement, Remove Bracket 2: step 8, image 2 of 2
    • Remove other smaller bolts.
  9. 2001 Audi TT Rear Differential Replacement, Unbolt From Car: step 9, image 1 of 1
    • Remove the 4 bolts on both sides that hold the rear differential in the car.
    • Be sure to have some sort of jack or object to hold the rear differential into the car as you continue to work.
Conclusão
Uma outra pessoa concluiu este guia.
Brenden Mitchell
Membro desde: 25/02/2018
196 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 60
Duração total: 2,529
