Ir para o conteúdo principal
2001-2005 Honda Civic Tail Light Replacement
O que você precisa
  1. 2001-2005 Honda Civic Tail Light Replacement, Tail Light: passo 1, imagem 1 %32
    • To remove the risk of electrocution, turn off the vehicle before attempting replacement
  2. 2001-2005 Honda Civic Tail Light Replacement: passo 2, imagem 1 %32
    • Release the trunk latch.
    • The release can often be found on the floor, near the fuel access and hood release buttons.
  3. 2001-2005 Honda Civic Tail Light Replacement: passo 3, imagem 1 %32
    • Remove bulb from tail light assembly.
  4. 2001-2005 Honda Civic Tail Light Replacement: passo 4, imagem 1 %32
    • Remove the bulb from its' socket.
    • Be sure to only remove the bulb. Removing the socket as well will require another replacement in order to properly function.
Conclusão
To re-install a tail light, follow these steps in reverse.
Tyler Smith
Membro desde: 10/23/13
846 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
Membros da 3
Autoria de 5 guias
Um comentário
I have an issue with the bulb being stuck in the socket. I can access the whole assembly fine, but for whatever reason the bulb won't come out.
Kyle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 42
Duração total: 8,431
