Ir para o conteúdo principal
2001-2005 Honda Civic Front Brake Pads and Rotor Replacement
O que você precisa
Instruções em vídeo
Conclusão
eCuration
Membro desde: 05/19/17
378.307 Reputação
Autoria de 236 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.908 guias
2 comentários
kudos for making the video. The main reason I like to “see” these jobs done is to know what to expect before I start a job. I haven’t seen an impact screw driver in forty years though!
Stephan Eichinger - Responder
Change your video… 80K views for a non-pro... The slots in the surface are for Gas Evacuation; ie: from the resin in the pads. The slotted rotors fins are for cooling. If you are in there for rotors: Why Not pull the pads ( and de-glaze with some emery-paper on a true surface). Pull and lube the sliders and re-anti-seize the pad-backs and clips ? ps: Compress the pistons makes sure they slide. This is basic brake-care and you should get at least two pads sets to one rotor replacement. ps: Don’t learn from me- i ain’t no pro. pps: Me too with a rotor-parts mix-up even after watching the 'Pro's' at SouthmainAuto and Ericthecarguy.
paul rattenbury - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 6
Últimos 7 dias: 21
Últimos 30 dias: 58
Duração total: 13,241
