Ir para o conteúdo principal
2000 Gmc Sierra Light Replacement
O que você precisa
  1. 2000 Gmc Sierra Light Replacement, Headlights, Taillights, and an overhead light: passo 1, imagem 1 %32
    • Open your tailgate fully, exposing both sides where the tailgate sits.
  2. 2000 Gmc Sierra Light Replacement: passo 2, imagem 1 %32
    • Unscrew the two phillips head screws located above and below the tailgate support.
  3. 2000 Gmc Sierra Light Replacement: passo 3, imagem 1 %32
    • Once the screws have been removed, simply pull off the taillight. The red plug is the taillight. Twist it a quarter turn counter clockwise, and pop it out.
  4. 2000 Gmc Sierra Light Replacement: passo 4, imagem 1 %32
    • Remove the old bulb and replace it with your new one.
    • Side note: Make sure replacement bulb is save voltage/amperage rating.
    • Open the hood and take a look above your headlights.
    • Two metal pins holding each of the headlights in place will need to be removed (no tool necessary).
    • Turn the plastic headlight mount counter clockwise by one quarter of a turn.
    • Then lift the pins up to fully remove them.
    • Once the pins have been removed, GENTLY pull your headlight upwards, towards you. The bulbs should now be exposed. The bulb on the top is your headlight.
    • As you did with the taillight bulb, turn the piece that is holding the bulb in place a quarter turn counter clockwise, and the bulb will pop out. Now your new bulb will take it's place.
Conclusão
5 outras pessoas executaram este guia.
keith beaudoin
Membro desde: 10/11/13
275 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013 Membro de UMass Dartmouth, Team 4-7, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G7
Membros da 2
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 534
