Ir para o conteúdo principal
2000-2006 BMW X5 Engine Advice
  1. 2000-2006 BMW X5 Engine Advice, 2000-2006 BMW X5 Engine Advice: passo 1, imagem 1 %32
    • Just a backseat image. the website wont take my other images.
Conclusão
I dont have many details except to go to bimmerfest for specific instructions. This was meant as a guide to BMW owners, knowledge from 20 years owning and x5, z3 and 330ix.
4 outras pessoas executaram este guia.
Paul Tast
Membro desde: 09/17/16
984 Reputação
Autoria de 7 guias
2 comentários
what are you even doing…
Thomas Adams - Responder
To Thomas or anyone else similarly confused...
The above 4-section advice addresses four recurring problems with the "in-line6" 1998-2006 BMX X5. It had many problems as a fairly new version of the x5. I have since then owned two newer models and all of these problems are resolved. In case you still dont understand the above, Ill summarize the above 4 quick-answers.
1 - The engine burns oil - The engine block has overheated is warped. Oil slips between the flat metal surfaces.
2 - Blocked gas filter - end of life gas filter indentification. This happens.
3 - This saves common problem IN ALL BMWs before 2000 saves owners $1500 by putting in your own AC final stage resistor.
4 - Avoid hours of figuring out replacing a door handle or window regulator (it moves the window up and down)
Hopefully this answers "What are you even doing..." <- This sentence lacks a puctuation and doesnt really ask a question FYI
Paul Tast - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 179
Ao todo: 1,425
