Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Remove the seat from your '99-'02 SV650 to gain access to your fuse box, tank hinge bolts and various other electrical connections.
O que você precisa
If you have frame covers below your seat, remove them by removing the 4 mm allen bolts holding them on. Use a 4 mm allen wrench to turn the screws counter-clockwise until they come off.
Once the frame covers are off, remove the 4 mm allen seat bolts on both sides of the seat. Use the 4 mm allen wrench to turn the screws counter-clockwise until they come off.
Lift the front of the seat, then pull it off the frame.
Uma outra pessoa concluiu este guia.
Um comentário
seat bolts are actually 6mm Allen (side covers are 4mm Allen).
