Ir para o conteúdo principal
1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement
O que você precisa
  1. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Plastic Rain Tray: passo 1, imagem 1 %32
    • Use a #2 Phillips screwdriver to remove the four screws.
  2. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 2, imagem 1 %32
    • Remove the rubber gasket from the rain tray.
  3. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 3, imagem 1 %32
    • Lift the tray upwards and away from the vehicle.
  4. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Front Windshield Wipers: passo 4, imagem 1 %32
    • Use a flathead screwdriver to remove the cap from the windshield wiper.
  5. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 5, imagem 1 %32
    • Use a socket wrench to release the passenger-side windshield wiper locking nut.
  6. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 6, imagem 1 %32 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 6, imagem 2 %32
    • Gently lift up the passenger-side windshield wiper.
  7. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 7, imagem 1 %32
    • Remove the driver-side windshield wiper in the same fashion.
  8. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: passo 8, imagem 1 %32 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement, Automatic Transmission Control Unit: passo 8, imagem 2 %32
    • Lift up the plastic cover.
  9. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 9, imagem 1 %32 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 9, imagem 2 %32
    • Use an offset Phillips screwdriver to remove a screw in the back of the automatic control unit cover.
    • In a pinch, you can make this tool with a phillips driver bit and end wrench.
  10. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 10, imagem 1 %32
    • Use a #2 Phillips screwdriver to remove the front two screws.
  11. 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 11, imagem 1 %32 1999-2004 Volkswagen Golf Automatic Transmission Control Unit Replacement: passo 11, imagem 2 %32
    • Gently unplug and lift out the automatic transmission control unit.
Conclusão
8 outras pessoas executaram este guia.
Matthew Newsom
Membro desde: 01/05/10
39.500 Reputação
Autoria de 67 guias
5 comentários
Does the new TCU need to be programmed in any way?? Or is it just plug and play.
Paul Newlove - Responder
does it need to be programmed mine needs replacement my gears are not shifting
dean wafula - Responder
got a question if your display light is dim what could be the problem
Volkswagen tiguan won't start after disconnection, wat can I do to restart it
Jusu Suapay - Responder
thank you very much .
emad_szs - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 33
Últimos 30 dias: 145
Duração total: 43,694
