Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This is to show how to replace the lift supports of the rear hatch. The hatch is quite heavy so use some sort of support or an assistant when changing the supports. the left and right strut are identically mounted. All steps apply to either side
O que você precisa
Open the tail gate and either prop it up or use an assistant to hold it.
Right tailgate lift support strut
Left tailgate lift support strut
To reassemble your Jeep, follow these instructions in reverse order.
8 outras pessoas executaram este guia.
4 comentários
We just had a garage replace the tailgate lift struts on our 2002 Jeep Grand Cherokee. Now the tail is very difficult to pull closed. Is there a way to adjust the struts so that it easier to pull down closed??
Double check the work. Make sure they are mounted the right direction and that all the bolts are properly fastend. There are no adjustments
I need to replace the lower bolt as it snapped in half. Any advice for that?
Use a drill and drill off the head. Remove the strut and use something like a pair of vise-grips and get a grip on the leftover part of the bolt. Try to remove it. If you can/ time to drill it out and retap the thread.
