Ir para o conteúdo principal
1999-2004 Honda Odyssey Coolant and Washer Fluid Check
O que você precisa
  1. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 1, imagem 1 %32 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 1, imagem 2 %32 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 1, imagem 3 %32
    • Turn off the car and pull the latch to release the hood.
  2. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 2, imagem 1 %32 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 2, imagem 2 %32 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 2, imagem 3 %32
    • Pull the hood release upwards to open the hood and use the prop rod to keep it open.
  3. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 3, imagem 1 %32
    • Locate the coolant container behind the passenger side headlight.
  4. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 4, imagem 1 %32
    • Check the fluid level is in between the max and the min mark on the coolant container. If it is at the max, proceed to step 7.
    • If the fluid level is below the max, you need to fill it up, continue to step 4.
    • If the coolant tank is empty, continue to step 4
    • Hot coolant is pressurized, make sure the vehicle is turned off for 15 minutes.
  5. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 5, imagem 1 %32
    • Loosen the coolant cap a little, then step back while the pressure releases. Now, completely remove the coolant cap.
    • Wait for any built-in pressure to release before completely removing the cap, pressurized coolant is hot and can scald.
    • Place a funnel on top of the coolant container opening
  6. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 6, imagem 1 %32
    • Use caution while handling coolant fluid. The product is flammable.
    • Pour the Prestone coolant liquid into the container until the liquid reaches the “max” line.
    • If you have a funnel. Place the funnel into the top of the container.
    • Pour the coolant liquid into the funnel until the liquid reaches the “max” line.
  7. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 7, imagem 1 %32
    • Firmly place the cap back onto the container.
  8. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Coolant: passo 8, imagem 1 %32
    • Close the hood.
    • If doing multiple checks closing the hood is not required.
  9. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 9, imagem 1 %32
    • Locate the Washer container.
  10. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 10, imagem 1 %32 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 10, imagem 2 %32
    • Open the washer fluid container and completely remove the cap.
  11. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 11, imagem 1 %32
    • Pour the Prestone washer liquid into the container until the liquid reaches the top of the container.
  12. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 12, imagem 1 %32
    • Place the cap back onto the container.
  13. 1999-2004 Honda Odyssey Coolant and Washer Fluid Check, Washer: passo 13, imagem 1 %32
    • Close the hood.
Linha de Chegada
Uma outra pessoa concluiu este guia.
TheGeorgeJr672
Membro desde: 07/02/21
247 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 2,814
