Ir para o conteúdo principal
1999-2007 GMC Sierra Alternator Replacement
O que você precisa
  1. 1999-2007 GMC Sierra Alternator Replacement, Alternator: passo 1, imagem 1 %32 1999-2007 GMC Sierra Alternator Replacement, Alternator: passo 1, imagem 2 %32
    • Using an 8mm wrench, disconnect the negative battery terminal. This is the one on the right (closest to the engine).
    • Caution: Hazardous situation which, if not avoided, could result in minor or moderate injury.
  2. 1999-2007 GMC Sierra Alternator Replacement: passo 2, imagem 1 %32 1999-2007 GMC Sierra Alternator Replacement: passo 2, imagem 2 %32
    • Loosen the hose clamps on the factory intake tube with an 8mm socket and remove the intake tube. One hose clamp will be located at the port of the intake manifold and one will be near the factory air box.
  3. 1999-2007 GMC Sierra Alternator Replacement: passo 3, imagem 1 %32 1999-2007 GMC Sierra Alternator Replacement: passo 3, imagem 2 %32 1999-2007 GMC Sierra Alternator Replacement: passo 3, imagem 3 %32
    • Remove the black wire from the back of the alternator using a 10mm socket and disconnect the voltage sensor. For the Voltage sensor, depress the tab towards the base of the sensor and pull outwards.
  4. 1999-2007 GMC Sierra Alternator Replacement: passo 4, imagem 1 %32 1999-2007 GMC Sierra Alternator Replacement: passo 4, imagem 2 %32
    • Using a 15mm socket on a half inch socket wrench, loosen the belt tensioner by pushing downwards. The tensioner is spring loaded so you will need to use your free hand to remove the serpentine belt.
  5. 1999-2007 GMC Sierra Alternator Replacement: passo 5, imagem 1 %32 1999-2007 GMC Sierra Alternator Replacement: passo 5, imagem 2 %32 1999-2007 GMC Sierra Alternator Replacement: passo 5, imagem 3 %32
    • Using a 16mm socket, remove both alternator mounting bolts and remove the alternator. These will be located at the base of the alternator. You may need a crowbar to remove the alternator from the mounting bracket because the mounting points often rust.
    • After replacing the alternator, make sure the battery is fully charged before starting the vehicle. You can do this by using a battery charger. Connect the red (positive) lead to the red (positive) battery terminal. Then do the same for the negative lead and terminal (black).
    • Set the charger to 12V and TRICKLE CHARGE, then wait until the indicator reads FULL CHARGE.
Conclusão
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 31
Últimos 30 dias: 104
Duração total: 6,567
