Ir para o conteúdo principal
1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation
O que você precisa
  1. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, imagem 1 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, imagem 2 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation, Truck High Mount Brake/Tail Lamp: passo 1, imagem 3 %32
    • Take the Philips screwdriver and remove two Philips head screws on both sides of the high mount brake lamp.
    • Be sure to store the two Philips screws in a safe place so they don't get lost.
  2. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 2, imagem 1 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 2, imagem 2 %32
    • Pull out the truck high mount brake/tail light housing.
    • We recommend you pull out the housing with both hands so you don't break the water tight seal.
    • If in the event that you happen you break it, you may have some water leak issues so you would have to fix the high mount brake/tail lamp housing with some glue.
  3. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, imagem 1 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, imagem 2 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 3, imagem 3 %32
    • Remove the stock bulbs from its socket.
  4. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 4, imagem 1 %32
    • Replace with the LED bulb.
    • Test your new LED truck high mount brake lamps to make sure everything works.
    • If the LED lights don't light up, check the polarity by flipping the bulbs 180 degrees.
  5. 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, imagem 1 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, imagem 2 %32 1999-2007 Chevrolet Silverado High Mount Brake/Tail Lamp Installation: passo 5, imagem 3 %32
    • Put back the light housing and screw in the two Philips screws.
Conclusão
Test and enjoy your new LED truck high mount brake/tail replacement lights.
Eric Wu
Membro desde: 01/21/15
3.357 Reputação
Autoria de 23 guias
2 comentários
The problem is there are no screws to remove.
richard - Responder
there are no screws to remove on my 3rd light I can’t change the bulb
richard - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 27
Duração total: 5,953
