Introdução
In this guild you will learn how to fix/replace your taillight on your Chevy Silverado truck. Often times, a taillight will randomly go out just from use or possible damage. Here is a quick 5 min fix showing you how do get the job done, save you a little money, and not go to the auto-shop to get it fixed.
The only tool needed for this fix will be a Philips head 2x100mm screwdriver.
O que você precisa
Use a Phillips screwdriver to remove the top and bottom screws that are in line with the tailgate.
To reassemble your device. Follow these instructions in reverse order.
