Ir para o conteúdo principal
1999-2007 Chevrolet Silverado Brake/Taillight Replacement
O que você precisa
  1. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement, Brake/Taillight: passo 1, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement, Brake/Taillight: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove the top and bottom screws that are in line with the tailgate.
  2. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 2, imagem 1 %32
    • Remove the taillight from housing.
  3. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 3, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 3, imagem 2 %32
    • Do a quarter twist to unlock damaged light.
    • You should feel the light housing stop once you unlock it.
  4. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 4, imagem 1 %32
    • Pull out the light from the housing
  5. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 5, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 5, imagem 2 %32
    • Remove the bulb from the socket.
  6. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 6, imagem 1 %32
    • Put in the new light.
  7. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 7, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 7, imagem 2 %32
    • Put the light and connection back in place and turn it back to the lock position.
  8. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 8, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 8, imagem 2 %32
    • Place the whole light back to where the screw holes on the tailgate side line up
  9. 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 9, imagem 1 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 9, imagem 2 %32 1999-2007 Chevrolet Silverado Brake/Taillight Replacement: passo 9, imagem 3 %32
    • Reinsert the screws and tighten until the taillight is secure.
Conclusão
To reassemble your device. Follow these instructions in reverse order.
Douglas Grymes
Membro desde: 10/23/23
169 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 74
