Ir para o conteúdo principal
1999-2011 Ford Ranger Tail Light Bulb Replacement
O que você precisa
  1. 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: passo 1, imagem 1 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: passo 1, imagem 2 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement, Tail Light Bulb: passo 1, imagem 3 %32
    • Pull the tailgate latch and lower the tailgate down so that it is open.
  2. 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 2, imagem 1 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 2, imagem 2 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 2, imagem 3 %32
    • Remove the two 19mm Phillips #1 screws on the taillight housing that face the inside of the bed.
    • Remove the two 38mm Phillips #1 screws on the taillight housing that face the outside of the truck.
  3. 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 3, imagem 1 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 3, imagem 2 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 3, imagem 3 %32
    • Pull the taillight housing down from the truck so that the wires and plugs are exposed.
  4. 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 4, imagem 1 %32
    • Remove any dirt or dust around the taillight plug so that nothing falls into the lens.
  5. 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 5, imagem 1 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 5, imagem 2 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 5, imagem 3 %32
    • Loosen and remove the taillight plug so that the bulb is exposed.
  6. 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 6, imagem 1 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 6, imagem 2 %32 1999-2011 Ford Ranger Tail Light Bulb Replacement: passo 6, imagem 3 %32
    • Remove the old or damaged bulb.
    • Insert the new bulb into the exposed plug and then insert the plug back into the taillight housing and tighten.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 108
Duração total: 6,984
