Introdução
This guide is applicable for any Accord made between 1998 and 2002.
O que você precisa
Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
8 outras pessoas executaram este guia.
4 comentários
My car radio is deactivated
I need the inside lighting fixture on the front top of the dash
How do you get the radio to turn on
