Ir para o conteúdo principal
1998 Honda Accord Center Dash Disassembly
O que você precisa
  1. 1998 Honda Accord Center Dash Disassembly, Center Dash: passo 1, imagem 1 %32
    • Before going any further: disconnect the battery. I keep a 10 mm wrench in my center console specifically for this purpose.
    • Use a 10 mm wrench to disconnect the negative battery terminal, followed by the positive terminal.
  2. 1998 Honda Accord Center Dash Disassembly: passo 2, imagem 1 %32
    • Note that the dash has been taken apart before, namely to install all those fancy gizmos you see in this picture.
    • The disassembly procedure is exactly the same for stock factory systems, but may differ when taking out the radio itself.
  3. 1998 Honda Accord Center Dash Disassembly: passo 3, imagem 1 %32
    • Use a #2 Philips screwdriver to remove the two screws holding the center of the dashboard in place.
  4. 1998 Honda Accord Center Dash Disassembly: passo 4, imagem 1 %32 1998 Honda Accord Center Dash Disassembly: passo 4, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Spudger
    $3.99
    Comprar
    • Use a spudger for the following step or, if you don't have one handy, cover a flathead screwdriver with a rag.
    • Gently insert a spudger or flathead screwdriver directly underneath the clock, just enough so you can pry out the clock. Perhaps a half inch or so will do it.
  5. 1998 Honda Accord Center Dash Disassembly: passo 5, imagem 1 %32 1998 Honda Accord Center Dash Disassembly: passo 5, imagem 2 %32
    • Slide the clock out to expose a sole Phillips screw.
    • Alternatively, you can first disconnect the clock (see next step) and then proceed to remove the screw. It might be slightly easier to do that instead of the method you see here, but either way will work fine.
    • Remove the screw using your Phillips #2 screwdriver.
  6. 1998 Honda Accord Center Dash Disassembly: passo 6, imagem 1 %32 1998 Honda Accord Center Dash Disassembly: passo 6, imagem 2 %32
    • Unplug the smaller connector first. There's a tab on top of the connector that you have to push downwards, then pull the connector. Make sure to grasp the connector itself, and not the wires.
    • Do the same with the larger connector. Again, there's a tab on top that needs to be pushed downward.
  7. 1998 Honda Accord Center Dash Disassembly: passo 7, imagem 1 %32
    • Now, gently pull the bottom of the center console towards you. Don't yank it out, there's two more connectors holding it in place.
  8. 1998 Honda Accord Center Dash Disassembly: passo 8, imagem 1 %32 1998 Honda Accord Center Dash Disassembly: passo 8, imagem 2 %32
    • First take off the red connector. Just like before, there's a tab on top of the connector that you have to push downwards first.
    • Follow suit with the green connector.
    • Center dash can now be fully removed.
Conclusão
8 outras pessoas executaram este guia.
4 comentários
Excellent Instructions. Toughest part is prying off the panel once you remove the screws and clock. The power connectors to the controls, (Hazards, Clock, Climate Control) can be a little tough too, wiggling helped.
Jason - Responder
My car radio is deactivated
Amelia davila - Responder
I need the inside lighting fixture on the front top of the dash
Robert Jones - Responder
How do you get the radio to turn on
Merlin Duston - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 64
Duração total: 33,011
