Introdução
The timing belt and water pump should be replaced together every 60,000-75,000 miles.
Follow this video tutorial by YouTuber NutzAboutBolts to complete the replacement yourself.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
5 outras pessoas executaram este guia.
7 comentários
Ok i did my timing belt and wather pump its a lot of work but you need to remember to mark your belt and line up wheels i got the timing spot on thanks to this pag
Isaac - Responder
Is the 99 Accord a single cam?
Mr. Mackmillion - Responder
My 1998 accord is leaking water from the right side what is it
Zac Johnson - Responder
Hi Zac, it’s not possible to accurately diagnose a leak over the internet. It would be best to have someone, or a mechanic, to physically look at it to locate the leak.
Blake Klein -
I added coolant to the radiator and all of it leaked out . On top of that the engine overheats in a few minutes of driving . What would be an appropriate diagnosis
Amadu - Responder
If coolant is leaking out and there’s overheating that means you have a leak somewhere. It would be best to take it to a mechanic to diagnose.
Blake Klein -
How do you line up you balance shafts if they are out of time. I bought a jam f23a 2.3L vtec that I'm dropping in but doing to maintenance to it first. The timing is off on all pulleys please help
Jonathan Bitter - Responder
