Ir para o conteúdo principal
1998-2002 Honda Accord Front Bumper Replacement
O que você precisa
  1. 1998-2002 Honda Accord Front Bumper Replacement, Front Bumper: passo 1, imagem 1 %32 1998-2002 Honda Accord Front Bumper Replacement, Front Bumper: passo 1, imagem 2 %32
    • Locate and remove the bolts in the front of the wheel well on the either side of the car using a #1 Phillips screw driver or an 8 mm socket wrench.
    • Locate the bolts on the bottom of both corners of the bumper and remove them using an 8 mm socket wrench or box end wrench.
  2. 1998-2002 Honda Accord Front Bumper Replacement: passo 2, imagem 1 %32 1998-2002 Honda Accord Front Bumper Replacement: passo 2, imagem 2 %32 1998-2002 Honda Accord Front Bumper Replacement: passo 2, imagem 3 %32
    • Locate the plastic push pins along the bottom of the bumper.
    • Use a small thin prying device, such as a flathead screwdriver, to pop the heads of the push pin up. Then remove the entire push pin assembly from their holes.
  3. 1998-2002 Honda Accord Front Bumper Replacement: passo 3, imagem 1 %32 1998-2002 Honda Accord Front Bumper Replacement: passo 3, imagem 2 %32 1998-2002 Honda Accord Front Bumper Replacement: passo 3, imagem 3 %32
    • Remove the push pins on the two raised portions of the bumper next to the inside of the headlights.
    • There are four clips along the top of the bumper still holding it in place. Gently lift the bumper while pulling it away from the car to free the clips and remove the bumper.
Conclusão
8 outras pessoas executaram este guia.
2 comentários
Awesome good directions and details
Eddie Jusino - Responder
This article and other online queries, lead me to believe that the 98’-02’ Accord Coupe bumpers are interchangeable.  Anyone know for sure?  I ask cos’ I want to replace my 99’ bumpers with 02’ bumpers, front and back.
Kenneth Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 19
Últimos 30 dias: 65
Duração total: 35,559
