Introdução
Use this guide to replace your 4-cylinder Honda Accord's distributor cap. This specific guide was created for a non-VTEC F23A5 engine, but other 4-cylinder Honda engines will be similar enough to follow the same basic steps
O que você precisa
Before disconnecting the spark plug wires, be sure to trace their orientation from the individual cylinders back to the distributor cap.
The cylinders are ordered from left to right when viewing the engine from the front of the car, with cylinder #1 being closest to the passenger side of the vehicle.
13 outras pessoas executaram este guia.
4 comentários
Where can I find the part number?
excellent, thanks for you aportation.
There is a problem with the order, the first cylinder is on the right not on the left, always next to the timing pulley, the numbering is opposite.
But following your reflection it is and all the same good
Denis bache - Responder
