O que você precisa
To finish your headlight bulb replacement, follow these instructions in reverse order.
16 outras pessoas executaram este guia.
Um comentário
The 2000 and 2001 Camry models take 9006 (HB4) bulbs for the low beams and 9005 (HB3) bulbs for the high beams, rather than the 9003 (HB2) linked here -- at least for the North American models I've looked up.
If you have the original owner's manual that came with the car, there's a table of all the bulb types you'll need for different lights in the "Do-It-Yourself Maintenance" section. It doesn't hurt to double check.
