Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
If using the car's emergency scissor-jack, identify the designated placement locations for this specific jack.
The jack needs to be placed behind the front tire in one of the two slots indicated by the red markers.
The slots are one foot behind each front tire, and 8-10 inches inward from the outer edge of the car.
Loosen the plastic lug nuts, located on the hub-cap, with a 19mm socket.
Loosen and remove the five metal lug nuts with a 19mm socket.
Loosen and remove the two bolts located on the backside of the caliper with a 12mm socket.
Remove the caliper from the mounting bracket.
Use a pry bar to remove the old brake pad from the bracket.
Use the same procedure for removing the pads on the other sides.
Pull the two caliper pins out of the mounting bracket by hand.
Before putting the new brake pads on, apply "Disc Brake Quiet" compound to the metal backing of the pads to keep them from squeaking.
8 outras pessoas executaram este guia.
