Introdução
Brake pads wear is one the most maintained thing that overlooked in the car. One of the few symptoms that related to brake pad problem are noisy or steering wheel pull to one side when braking. This guide will help solve those problems by changing the front brake pads for 1997 to 2003 Chevrolet Malibu.
O que você precisa
If using the car's emergency scissor-jack, identify the designated placement locations for this specific jack.
The jack needs to be placed behind the front tire in one of the two slots indicated by the red markers.
The slots are one foot behind each front tire, and 8-10 inches inward from the outer edge of the car.
To reinstall brake pad, follow in reserve order. It is important to do a test drive since the brake may feel soft the first time after a new brake pad.
8 outras pessoas executaram este guia.
