Introdução
If you own an older vehicle you know that the factory light bulbs usually aren’t very bright. In this guide I will be showing you how to replace the tired old factory lights with brand new LED replacements that will help you see your dash better and give a new look to an old car. This guide is specific for a 2001 Jeep Wrangler TJ.
O que você precisa
Remove the old light bulbs from the dash and replace them with the new ones. To do so simply twist the body of the light and it will pop right out. To install the new bulbs do the opposite. Push the body of the bulb flush with the mounting surface on the dash and then twist to hold it tight.
