Ir para o conteúdo principal
1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement
O que você precisa
  1. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement, Instrument Cluster Light Bulbs: passo 1, imagem 1 %32
    • First a look at the original lights in the dash.
  2. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 2, imagem 1 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 2, imagem 2 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 2, imagem 3 %32
    • Remove the three screws along the top of the dash cluster.
    • There is a cover to gain access to the top two of four screws that hold the cluster in.
  3. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 3, imagem 1 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 3, imagem 2 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 3, imagem 3 %32
    • Remove the two screws that hold the second part of the dash cluster, then remove the dash cluster.
  4. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 4, imagem 1 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 4, imagem 2 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 4, imagem 3 %32
    • Now that all four screws holding the dash on are visible, remove them to allow the dash to come off.
  5. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 5, imagem 1 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 5, imagem 2 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 5, imagem 3 %32
    • Assemble the new lights by pushing the butt end of the bulb down into the body until seated fully.
    • The bulbs are polarity sensitive so pay attention to the direction that you put them in.
  6. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 6, imagem 1 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 6, imagem 2 %32 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 6, imagem 3 %32
    • Remove the old light bulbs from the dash and replace them with the new ones. To do so simply twist the body of the light and it will pop right out. To install the new bulbs do the opposite. Push the body of the bulb flush with the mounting surface on the dash and then twist to hold it tight.
  7. 1997-2006 Jeep Wrangler Instrument Cluster Light Bulb Replacement: passo 7, imagem 1 %32
    • The final step is the reassembly. This is very easy as you simply repeat the steps taken to remove the dash but in opposite order. If upon reassembly you find some of the lights not working simply remove the bulb in question and switch the direction of the bulb in the body. That will fix the problem. As you can see the result is well worth it.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 81
Duração total: 10,406
