Pular para o conteúdo principal
Introdução
Here you will learn how to remove the wood panel from the center dash unit. After doing this guide you will be free to get to the center dash and stereo/cd/cassete players.
Peças
Nenhum componente especificado.
  1. Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips.  Be careful on the thin sections below the head unit as to not snap the trim.
    • Using a panel tool or long flat head screwdriver, pry the wood grain trim off and release the clips. Be careful on the thin sections below the head unit as to not snap the trim.
  2. Kit de Reparo de Bateria do MacBook
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
    • Detach the wiring harness from the back of the air conditioning control unit by pushing down on the top middle tab and pulling apart using a screwdriver for leverage if necessary.
Conclusão
2 outras pessoas concluíram este guia.
Brayden
Membro desde: 05-10-2012
13 reputação
5 Guias de autoria
Equipe
Cal Poly, Team 18-42, Regan Fall 2012 Membro de Cal Poly, Team 18-42, Regan Fall 2012
CPSU-REGAN-F12S18G42
4 Membros
5 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Todo: 2,069
