Introdução
Whether your bulb is burned out or require an upgrade, learn how to replace the bulb in your 1996-2000 model year Honda Civic
O que você precisa
Pop the hood via hood release latch by driver's side.
Reach for the latch under the hood and prop the hood up on the prop rod.
Test your new headlight bulbs and make sure they function properly. If they do not work at first, try cleaning off the connection mating your new bulb and its connector.
To reassemble your components, follow these instructions in reverse order.
